The Daily CLAD
Community Browser
Re: Unbundle - Bundle
SercoSteveB
Active Participant
Which of the following are possible values for Output Cluster 1 following execution of the VI?
Comments
crossrulz
Knight of NI
A and B
GCentral
mini09
Active Participant
A & B. Cluster Ordering plays the trick here...
Nice one Steve:)
clendon.gibson@canrig.com
A, B, C or D,
The order of the displayed cluster elements is unknown. If we presume that Steve just took the cluster directly then A and B make sense. But Steve is tricksie and the cluster elements don't have their labels showing. (They could be reordered so that the second element displays on top.)
MrStevenUND
I agree with Clendon.  How much do we trust Steve?  I think that is the real question here.
Without labels, it could be any of them.  Assuming Steve didn't reorder the Output Cluster on the FP, A & B.
Bioengineer_UM
I got the same answer as B.
But I'm not fully understand of the question concept, share please if there further explanation on that.
Thanks.
SercoSteveB
Active Participant
This question is about the problems that may occur when using the Bundle and Unbundle nodes (rather than Bundle by Name and Unbundle by Name).  More of a discussion question.  In hindsight I should have labelled the FP items.
...... you can trust me .......honest
SercoSteveB
Active Participant
Hi Bioengineer_UM.  HINT:  Think about what defines the order of the items within the cluster constant on the block diagram.
cadiz1
Taught me to check the order. Thanks. tricky
cadiz1
Taught  me to check the order. Tricky
Yamoussa
I tried and got B
ashwinilele
A and B
SercoSteveB
Active Participant
Answer: A, B, C & D.  Nice one clendon.gibson@canrig.com.
More of a discussion question this one.  In my mind, when writing, I was thinking that we do not know the order of the numeric constants in the cluster constant or how the elements in the output cluster have been positioned.
sardarsree
Utlimate question and answer...
