Before executing this VI a developer enables 'Unit Labels' from the right-click shortcut menu of both 'Constant Value In' and 'Numeric Value Out'.
NOTE: The right click shortcut menu is accessed from the Block Diagram for 'Constant Value In' and from the Front Panel for 'Numeric Value Out'
If the Unit Label of 'Constant Value In' is set to km (as shown) and the Unit Label of 'Numeric Value Out' is set to m; what is 'Numeric Value Out' following execution of the VI?
