The Daily CLAD
Community Browser
Re: Unit Label?
SercoSteveB
Active Participant
Before executing this VI a developer enables 'Unit Labels' from the right-click shortcut menu of both 'Constant Value In' and 'Numeric Value Out'.
NOTE: The right click shortcut menu is accessed from the Block Diagram for 'Constant Value In' and from the Front Panel for 'Numeric Value Out'
If the Unit Label of 'Constant Value In' is set to km (as shown) and the Unit Label of 'Numeric Value Out' is set to m; what is 'Numeric Value Out' following execution of the VI?
Comments
crossrulz
Knight of NI
C
GCentral
LordNobady
C as I understand it LV takes the SI unit in consideration.
Learning LabVIEW since January 2013
Musale
how can i create unit labels??
LordNobady
Right click on the constant or the front panel control or indicator. select visible items, unit labels. now you can set the unit.
mini09
Active Participant
C ....
SercoSteveB
Active Participant
Answer: C.  Nice one crossrulz, LordNobady & gnshmrthy.
Only found out about Unit Labels the other day, not sure what I think about it yet.  Any use cases out there?
ashwinilele
C
AuZn
Apparently English unit also works. But I just don't feel comfortable to leave unit conversion to LabVIEW.
Also, just came across this: Available Units in LabVIEW
