Assuming initial values for Boolean 1, Boolean 2 and Boolean 3 of FALSE. If the user runs the VI and then performs a left mouse click on Boolean 2 that fires the Value Change event shown in the snippet, what value is passed to Numeric Value Out?
NOTE: There are no hidden cases in the Event Structure.
a) 0
b) 1
c) 2
d) 4
