Place the following Variables Types in order from top to bottom?
a) Single Process Shared, Network Published Shared, Local, Global
b) Single Process Shared, Network Published Shared, Global, Local
c) Network Published Shared, Single Process Shared, Local, Global
d) Network Published Shared, Single Process Shared, Global, Local
