Describe the plots on Waveform Graph following an execution of the VI?
a) 1 graph plot with 15 equally spaced data points.
b) 3 individual graph plots, each with 5 equally spaced data points.
c) 5 individual graph plots, each with 3 equally spaced data points.
d) 15 individual graph plots, each with 1 data point.
