Troubleshooting Hardware
Damaged roboRIO 2.0 (SD card port)
We purchased the roboRIO 2.0 last season and have struggled to implement it on a robot due to issues with the SD card port.  The provided card will not eject properly.  We, unfortunately, damaged the card in an attempt to remove it.  We've since replaced the card and reimaged it using the roboRIO Imaging Tool.  It took multiple attempts to reimage but finally got a successful image, only to discover that the card is not read by the RIO.  So basically, we don't know if the unit came in damaged or not.  We're wondering if it can be repaired or needs to be replaced.
(1,642 Views)
Hello KinematicWolves,
I'm Matthew at NI; thanks for posting on the forums.
The roboRIO 2 only uses the roboRIO imaging tool to set the team number. Instead, can you try using either balenaEtcher or Raspberry Pi Imager (as detailed here: https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html#writing-the-image-...) to copy the image the SD card?
(1,628 Views)
We did that as well.
(1,619 Views)
I sent you a private message on next steps.
(1,612 Views)
I'm sorry to cross-post, but I can't figure out how to create a new post.  I have a damaged CAN port on my RoboRIO, (pin broken off inside).  How can I get it repaired?
(1,454 Views)
Send you a direct message to get more details.
For anyone else looking at this thread, please open a new one with your request to ensure we get to it and it does not go unanswered.
Cheers,
(1,431 Views)
