Troubleshooting Hardware
USB Ports not working on (2) roborios s/n 31617CF and s/n 312DAE7
We have (2) RoboRios that have bad USB Ports.  What can we do?
Message 1 of 11
(1,797 Views)
Hi cls1961,
Thank you for posting on the forums; I'm Matthew with NI.
Can you describe what the problem with the ports are? (and is this the type A ports or the type B ports?)
Message 2 of 11
(1,779 Views)
Hi Matt, they are both the b port and they both have the same issues. Bad connection issues. Sometimes they connect and lose connecting.  Sometimes they won’t connect at all. We have others that work.
Message 3 of 11
(1,770 Views)
Matt, a little further description.  Sometimes you can wiggle the cable to get it to connect, then they lose connection while your using the robot, then sometimes they wont connect at all.  It seems like it the ports, but I suppose there could be a common internal issue with the USB boards?
Both have the same issues.  We had purchased another that works fine and our new RoboRio 2 is good.
But, we would really like these working for our test control stations, training and practice robots.
Message 4 of 11
(1,760 Views)
Please respond
Message 5 of 11
(1,739 Views)
That sounds like the USB ports have worn down. (That is one of the downsides to the type-b connector).
Since all communication with the robots can be done over ethernet, is that a workaround that you're ok with?
Message 6 of 11
(1,719 Views)
Maybe I am misunderstanding.
Can we update firmware via the ethernet connection vs the usb?
this years First WPILib code will not work unless the roborio is flashed with this year's firmware.
please explain.
Message 7 of 11
(1,715 Views)
Yes, you can connect to the roboRIO directly via ethernet to flash firmware and deploy code. (this is a secondary option because it require configuring network communication; however, my old team has taken to always using this method always because their USB port died in an accident years ago).
There is a doc on how to configure network settings on Windows if they don't talk correctly out of the gate: https://docs.wpilib.org/en/stable/docs/networking/networking-introduction/roborio-network-troublesho...
Message 8 of 11
(1,705 Views)
Matt-  Our preference would be to get these working.  Is there a way we can accomplish that?
Message 9 of 11
(1,689 Views)
Matt-
You never responded to my last submission?
Message 10 of 11
(1,633 Views)
