Troubleshooting Hardware
Northport roboRio 2, not able to communicate with brand new roboRio 2
We can update the firmware but not able to communicate with Roborio thru drive station or VS Code. We were able to format the new Roborio but thsat is it.
(975 Views)
Hi EPMoloney,
Thank you for posting on the forums, this is Matthew from NI.
Since this is a roboRIO 2, can you confirm that you've imaged the SD card (https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html)
Can you try another SD card?
If that doesn't work, can you try booting the robRIO into safe mode https://docs.wpilib.org/en/stable/docs/software/roborio-info/recovering-a-roborio-using-safe-mode.ht... ?
(955 Views)
(935 Views)
