Troubleshooting Hardware
Problem with NI-9266 Module
Hello, I was inquiring about a problem that occurred to me when I was trying to operate the NI-9266 Analog Output Module, When I gave it power [24V DC] and it was connected to a NI-9147 chassis it gave out this warning [65543] and the card did not output any current.
I also tried it on a different chassis [NI-9149] in a completely different setup with supply voltage [9V and then 12V] and it still gave me the same warning, attached is a picture of the warning from LabVIEW.
The code is just a while loop with a 50ms wait and an analog A0 shared variable that has a controller wired to itIMG-20240320-WA0012.jpg
(806 Views)
Hi MKG000,
This forum is dedicated to troubleshooting issues related to RoboRIOs, not CRIOs. If you're encountering problems with RoboRIO, kindly consider creating a support ticket or posting your query in the appropriate forum. Thank you for your understanding!
(754 Views)
Oh I'm sorry about that, thanks for the reply I'll post it there.
(749 Views)
