Troubleshooting Hardware
Robo Rio 2.0
Our Robo Rio 2.0 will not power up.
(614 Views)
Commenting on this so an NI employee sees this.
(541 Views)
Hi
This is Diego with NI.
When you mentioned that the device is not powering up, is not showing any blinking on the leds? Could you share a picture of the Roborio?
Also, in some cases, this issue can be caused by a short in the contact. with the device open (removing the screws on the back and the two screws at the port, this will not void the warranty):
  1. Turn the roboRIO upside down and shake it vigorously.
  2. Vacuuming out the ports on the roboRIO.
  3. Check with a flashlight for material making contact in the port pinouts.
(529 Views)
