03-21-2024 03:32 PM - edited 03-21-2024 04:24 PM
Today at our competition we found out that the DIO ports on our RoboRIO aren't working. How can we get this fixed or replaced?
Update: I talked to another team and apparently they have had the same issue. The specific issue is that the 5 volt and ground lines for the DIO and analog ports are shorted together. What could be going on here?
03-21-2024 05:00 PM
You can delete this post. We found the issue. It was a very tiny piece of wire in the expansion port shorting things out.
03-22-2024 09:37 AM
Hi Derek.Ward,
My name is Jess, I'm with NI, thank you for posting in the forums. I'm glad you found the root cause, your update is appreciated, and it might help other teams that run into the same issue.
