Troubleshooting Hardware
RoboRIO unresponsive.
Hello!
we have a roborio that we're not able to connect to or to load code.   I have a video of the lights when it is powered on, but its just a  video file (not online/youtube).  Let me know where i can email the file to.
When connected to power, the power light is red (on), and that status light does a repeating sequence of double flashes.  no other signs of life.
Please advise.
Jim
FRC1255
(1,173 Views)
Hi, JFox100
I'm Matthew with NI. Thanks for posting on the forums.
Is the original roboRIO (has a "National Instruments" logo and a LabVIEW logo), or the V2 (has a micro-SD card slot, an "ni" logo, and says "v2")?
According to the docs: https://docs.wpilib.org/en/stable/docs/hardware/hardware-basics/status-lights-ref.html
a double flash means the device is recognizing a software error and needs to be re-imaged.
You can see details on how to do this
for the v1: https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/imaging-your-roborio.html
for the v2: https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html
If doing those steps doesn't get it working, can you try booting the roboRIO into safe mode (https://docs.wpilib.org/en/stable/docs/software/roborio-info/recovering-a-roborio-using-safe-mode.ht...)?
(1,167 Views)
Hi!
It is the original rio.   there is no way to connect to the rio. It wont connect, therefore there is no way to update firmware or software.
Where can i send the video?
Jim
(1,140 Views)
Accepted by oscarfonseca
To make sure I understand correctly, it won't connect even in safe mode (hot to get it into safe mode: https://docs.wpilib.org/en/stable/docs/software/roborio-info/recovering-a-roborio-using-safe-mode.ht...)?
(1,137 Views)
Hello!
I passed along your link to my team last night.  They were able to recover the RoboRIO!     Thanks for your guidance!
Jim
FRC1255
(1,115 Views)
