Troubleshooting Hardware
Roborio 2.0 red and orange blinking leds
our Roborio 2.0 is blinking red and orange
the blinking led are not sync
we cleaned the roborio PCB board
please advice
(725 Views)
Hi Tal3339,
My name is Jessica, I'm with NI. We saw you have a different post for the same issue: Roborio 2.0 RED LED - NI Community. Is this for the same device?
(692 Views)
No, I do have two devices both are not working
(682 Views)
Hi Tal3339,
We've encountered similar issues before when the SD card comes unseated. Could you try to take out the SD card, check the slot for any metal debris (perhaps by turning it upside down and shaking it firmly), and then place the card back securely? If possible, go over the device again with compressed air.
Another thing you can try is to use a different SD card (remove any stickers that may be on it). Use the process described here to reimage the roboRIO SD card: roboRIO 2.0 microSD Card Imaging (Supported image files are named FRC_roboRIO2_YEAR_VERSION.img.zip). Once the SD card is imaged, reinsert it to the roboRIO and connect it to your computer by USB to set the team number using the roboRIO Imaging Tool.
(664 Views)
