Troubleshooting Hardware
Roborio 2.0 sd card port spring not functional
My frc team roborio 2.0 sdcard port won't reject the sd card, we tried loosening screws and had no luck.
(1,063 Views)
Is this the right forum for this, how do I obtain an RMA?
(1,037 Views)
This is Diego from NI.
To assist you, could you please share some pictures of the slot?
Once we have that we will be sending you a private message to proceed with the RMA
(1,032 Views)
Hi, vargoos84, thanks for posting on the forums. I'm Matthew with NI.
To clarify, if you gently press on the SD card and then release it doesn't eject?
(1,031 Views)
This is correct, we pushed down on the memory card (which seemed lower than most, usually a good fingernail will do it), and it did spring up.  We used a precision tool to pull the card out.
See attached for pictures.
(1,022 Views)
Hi Vargoos,
I've sent you a direct message to coordinate the repair
(1,004 Views)
