Troubleshooting Hardware
Roborio not connecting
Hello! I am having issues connecting my Roborio (v1) through Ethernet both directly to the computer and to the radio. The connection is very interment. We can connect and image the Roborio through the USB connection. We do have a second Roborio that works with the same setup.
(1,347 Views)
Hi Team 1647,
My name is Jessica, I work at NI.
I understand you have a roboRIO that can't connect to your computer through Ethernet. Could you go through the next steps to try to narrow down the issue further?
  • Try using an Ethernet cable you're sure that works properly.
  • Try connecting to the roboRIO on another computer.
  • Try connecting to a different, known-working network connection (i.e. another wall port or another port on the router you are using.)
  • Try to reimage the device from safe mode.
(1,023 Views)
