Troubleshooting Hardware
roboRIO 2.0 Bad DIO
The DIO ports on our roboRIO 2.0 stopped working during a match and we haven't been able to recover use.  Have tried all of the ports, must be fried internally.
(200 Views)
My name is Esteban Sanarrucia I'm from NI Tech Support,
Could you please check that there is no debris obstructing the ports or causing an internal short circuit? You can use a flashlight for inspection, and also try turning the roboRIO upside down and shaking it vigorously.
(168 Views)
