Troubleshooting Hardware
roboRIO 2.0 unresponsive.
roboRIO 2.0 stops responding, randomly disconnecting during our Orlando/Tallahassee regionals. We had random connection errors at both regionals so we were advised to try swapping to a loaner roboRIO 1.0 and our robot ran consistently for the next 7 matches and elimination rounds.
Mentor suggested I attempt to start the RMA process on a 2.0 since he wants to use it instead of the 1.0's we already own.
(1,377 Views)
Hi Murphalicious1056,
Thanks for posting on the forums. I'm Matthew with NI.
Connection issues can be caused by a number of situations (including loose wiring). Any chance you still have the driver station logs from those matches?
(1,350 Views)
Thank you for the help Mathew,
I don't have the logs from the matches.
We had what the field tech called "annoyingly random" issues all through Orlando and no issues once we swapped out the roboRIO a couple of matches into Tallahassee. After the swap we had no problems all the way through 9 qual matches and 4 matches in semifinals.
Murphy
(1,331 Views)
