Troubleshooting Hardware
roboRIO continuous flashing status led (unrecoverable error)
Hi! Greetings from Team 5705,
We're having the same trouble trying to flash our roboRIO, we've already tried everything described on the device's manual, as well as in this forum.
Does someone have a solution for this?? Our roboRIO has definetely died?
The device turns on, but it doesn't appears on the Imaging tool, the tool displays a "<No RoboRIO targets found>" sign with a yellow warning triangle as shown below.
And also we've tried using several laptops with different Windows versions, but unfortunately it's the same thing.
We'll be so thankful if someone provides us a way to solve this.
Thank you very much in advance.
(1,185 Views)
When you power on the roboRIO, what do you see with the LEDs?  From there, I have a couple of ideas how to move forward depending on what you're seeing.
(1,122 Views)
