Troubleshooting Hardware
Roborio unable to image, continuous flashing status LED
We turned on our 2019 robot for a demo to find out that there was no robot code. This led us to discover via the imaging tool that there was no firmware on the rio. Trying to format target or update firmware failed. We tried running the imager as an administrator, disconnected the ethernet so we were only connected via USB and that failed, so we tried booting the rio into safe mode, which gave us a continuously flashing LED. Rebotting without safe mode allows it to be found in the imaging tool, but still shows unknown for firmware, and FRC_roboRIO_2019_v14 for the current image.
Any suggestions appreciated.
Message 1 of 11
(2,824 Views)
Since you've already tried safe mode and running the tool in admin mode, we may need to go ahead and try to reset the device. I've sent you details in a private message.
Message 2 of 11
(2,818 Views)
Hello
We have the same issue. We bought a roboRio from a retired FRC team, and try to imagine it, But always failed. Here is the error message:
We tried the suggestion listed, But they doesn't fix the issue. Here is the FRC game tool screenshot.
Message 3 of 11
(2,737 Views)
Does it work if you first "update" the firmware to a 5. version?
Message 4 of 11
(2,732 Views)
Hi Mshafer
Thanks for your reply. We only have firmware 6.0, Is there any way to download firmware 5.0?
Jin
Message 5 of 11
(2,723 Views)
Official answer:
"Install an older version of the Game Tools"
I'm having trouble finding you a link... (you can read more on this thread: https://forums.ni.com/t5/Troubleshooting-Hardware/Roborio-Unrecoverable-Error/m-p/4118143#M27)
Message 6 of 11
(2,684 Views)
Thanks for the reply. I installed firmware 5.0.0, But the error is still there. Here is the screenshot, May you take a look?
Does it cause by disk damage? Can I use the software to block the damaged partition?
Thanks again for all your help!
Message 7 of 11
(2,665 Views)
@linjin8848, I followed up with a colleague. They said if you're in the constant flash mode that we'll need to just try the re-flash anyways. I sent you instructions in a private message.
Message 8 of 11
(2,664 Views)
@mshafer, Can you send me those instructions as well?  We have two Rio 2.0s that are having the same issue.
Thanks.
Message 9 of 11
(2,503 Views)
For the roboRIO 2, this option has been replaced by formatting the SD card - https://docs.wpilib.org/en/stable/docs/software/roborio-info/roborio2-imaging.html
Message 10 of 11
(2,498 Views)
