10-09-2013 11:27 PM
Our ALOHA framework supports windows that can float or "dock" into a container window. It is a free framework. You can check it out at http://www.seneca5.com/aloha.html.
Each of the VI's run as a separate Agent. The framework can doc them into a parent window by using subpanels. A VI can be inserted/removed from a sub-panel any time you want, even if it is running. ALOHA manages all that for you. Or you can dive down into our code to see how it was done.
		01-04-2016
		06:29 AM
 - last edited on
		04-26-2025
		06:48 PM
 by
			Content Cleaner
I made a C# control to load a .net docking library to use inside a Labview .Net control. See example https://forums.ni.com/t5/Example-Code/Test-of-NET-docking-libraries-using-Labview/ta-p/3534617
