UI Interest Group Discussions
How to Dispaly Multiple Actions with Single Boolean Control in LabView
Am doing a GUI Based project for the Calibration System of Flow Meters and in this i need to control the Quick Acting Valves, In my Programming i am Using stacked sequences and in several sequences am using boolean constants to give signals to the hardware module for opening and closing of valves.At this same time i need to display this actions in the boolean in my front panel.i need to feed my output from constants to same Valve Boolean Indicators for multiple times at various sequences. I couldnt feed this out of Stacked Sequence for Multiple times.Please explain.
(5,751 Views)
Hi aswin,
to discuss LabVIEW programming problems you should post in the LabVIEW discussion forum.
After you have done this you will receive a lot of help messages. The main conclusion will be to convert your stacked sequence into a proper state machine! Once you have done so you can easily display the current state of your valves in FP indicators…
(4,425 Views)
Gerd is right,
go to labview discussions.
but quick here:
The valves should give a feedback if they are Open or Closed. You do not want to show if the program (or the operator) gave a Command but the Real State.
If you do think it is necessary, a simple two state bool won't do. The system-type controls have a mixed indicator or you can build your own.
Good luck, Gabi
7.1 -- 2013
CLA
(4,425 Views)
Use a local variable.
(4,425 Views)
thank you all\
(4,425 Views)
