UI Interest Group Discussions
User Interface for Multiple Sensors
Hi all,
I want to create an application where in i should be able to acquire data for Accelerometer, pressure, strain, LVDT and Temperature sensors. I want to create a Font Panel as shown in the attachment, i should configure any of the sensors by selecting the check box. Please find the attachment.
Any help regarding how to go about it, I would be really glad if you any ideas.
Kamasani
KM
(5,332 Views)
Is the checkbox absolutely necessary? Because if not, you can use a tab, with each sensor in a separate page.
Danielle
"Wisdom comes from experience. Experience is often a result of lack of wisdom.”
― Terry Pratchett
(4,044 Views)
Hi thanks for your time,
not absolutely for checkbox, but i need to create radio buttons for sensor selection in the similar way.
KM
(4,044 Views)
Your Main.vi has the basis of your plugin architecture quite well. You seem to have answered your question yourself In order to load the sensors dynamically, look at the calculator example.
Danielle
― Terry Pratchett
(4,044 Views)
