UI Interest Group Discussions
Proyect Wind Turbine Pic18F4550 Labview 2009
I'm trying to understand which "parts" you have working and which "parts" are not working.
Fundamentally, there are two "parts": The PIC running C code and the PC running LabVIEW. Is either of these known to be working?
That is:
Is your PIC using C code putting out USB data?
Is your PC using LabVIEW code able to read USB data (from any source)?
Message 11 of 15
(1,848 Views)
A if there are two parts one that corresponds to pic 18F4550 and the other labview 2009
and questions about the pic I use what I program in c with respect to your second question asks which means to be able to read data from USB (from any source)
Message 12 of 15
(1,848 Views)
But you understand what I'm going with labview?
is able to monitor the speed of the wind direction rpm etc.
Message 13 of 15
(1,848 Views)
Could you gentlemen carry on this conversation directly without using the NI Community - UI Interest Group. Each reply gets broadcast to the world and we do not need to know every detail of your conversation on the road to a solution.  Thanks
Paul Conaway
Message 14 of 15
(1,848 Views)
Estimated paul,
this is not a forum where they can contribute ideas that everyone is wrong or apologize if I upset you our comments and my idea is that all people regardless of who is not that you take it the wrong way can participate
greetings from chile a hug
Message 15 of 15
(1,848 Views)
