USRP Software Radio
B210 DC Power Issue
Looking for some help with an issue we're having with both of our B210 boards.  Note: Ettus hasn't responded to support request originally sent almost a month ago.
Problem: B210 turns off when DC power adapter is plugged in or fails to turn on when DC power is connected.
Anyone know why this is happening and what we can do to fix it?  Our use case is going to require a long unpowered USB connection to the radio.
Otherwise the Radio works fine when powered by USB only.
(2,165 Views)
Solved: the LED just turns off, but once it's sent commands by the USB connection it turns the LED back on.
(2,134 Views)
