USRP Software Radio
NEED A "NI EXTRACT FRAME" VI TO SOLVE SYNCHRONISATION ISSUE
Hi wonderful community,
I need to ask a doubt related to frame synchronization,
I am implementing simple noma -ofdm where I receive correct message but after some weird message. If you could provide internal implementation of extract frame part may be I will be able to resolve the issue.
(1,588 Views)
I have no idea what your question means.  What is "noma -ofdm"?  Where is the LabVIEW code?  It is best saved as a LabVIEW 2019 or 2021 VI, with enough sub-VIs that it can be opened by us without "missing VI" errors -- an error-free "Snippet" should also work (as long as we can open it).
Bob Schor
(1,552 Views)
hey here is the code
OFDM .
How to do frame synchronization
(1,529 Views)
Ah, thank you.  Sounds like you are using NI's USRP stuff.  There's not too much traffic with this specialized topic on the general LabVIEW Forum, but there's another Forum here where most of the participants will at least understand your question.
Bob Schor
(1,495 Views)
