USRP Software Radio
Basic questions about USRP
Hi
I started learn Labview with using USRP-2922. Currently I just set up the system and understanding examples. Whenever I open modified example file, it's IP adress always same as default although I changed and saved as another file. Also Whenever I want to change frequency range by using this path > right click on graph > Scales> Unclick autoscale and entering min and max. values, it seems changed but after closing and opening the file it is not changed. How can I save my changes on my files. In addition, could you give more examples(to learn step by step), datasheets and white papers about USRP? Regards
(4,505 Views)
You can modify the values in the controls in the front panels, and go to "Edit" in the toolbar,
,click "Make Current Values Default", and save the VI before closing it.
Rui
(4,491 Views)
Dear Rui, Thanks for reply. I changed IP adress but I could not modify graph axis. I want to change frequency range and whenever I started  my modified file, I want to see modified frequency range. Could anyone help me about this matter?Thanks.
(4,487 Views)
Which example are you running?  I would think the graph would autorange to whatever frequency range you USRP is using.  Just changing the range on the graph isn't going to change the actual data being displayed.
(4,379 Views)
