USRP Software Radio
BasicTx and BasicRx daughter boards compatibility with USRP2920 and LabView
I want to know that BasicTx and Basic Rx daughter boards from Ettus research are compatible with USRP2920 and Labview or not.
Also do these boards supports variable gain or not? Please confirm
JK
(5,501 Views)
Accepted by josephkirmani
They will work but you need to use property nodes to configure them. Ther is no LO so ther is no center frequency parameter. I and Q are separate channels so you will need to break them apart and treat them as such. There is no gain because the boards essentially provide access to the ADC.
(5,496 Views)
