USRP Software Radio
Buffer clear ?
Lian,
ErikL的意思翻译为:
VI with green play arrow  带绿色开始箭头的VI,即niUSRP initiate.vi
VI with red stop square    带公色方块的停止VI,即niUSRPAbort.vi
这两个VI可以开始和停止采集
同步VI可以指定触发时间,在触发事件到达之前,是不会开始采集的。
Xiaodong Qi
NISH AE
China
Message 11 of 14
(4,228 Views)
  part A will send a packet on channel 915Mhz instantly once it receive an ack from part C on channel 1Ghz, and part B receieve data of part A on channel 915Mhz .
 Is it possible to receive the data from different channel (A - 915Mhz, C - 1 GHz), then A communicates with B in 915Mhz channel? do you configure the channel dynamically? aa
Message 12 of 14
(4,217 Views)
No, we use the Tx1 and Rx2 of NI-Usrp 2920 at the same time.
Message 13 of 14
(4,212 Views)
aah, your USRP support duplex, mine (2921) could only use 1 at a time
Message 14 of 14
(4,208 Views)
