USRP Software Radio
Can NI-USRP be worked on GNU Radio?
Hi BHANU_India,
It is possible to use GNU Radio with an NI USRP. However, using the HW with GNU radio isn't supported by NI. I reccomend contacting Ettus support at https://www.ettus.com/support
Message 21 of 31
(5,788 Views)
Message 22 of 31
(5,787 Views)
Is UHD needed for LabView?
Message 23 of 31
(5,775 Views)
If we are installing directly UHD then why many environment are needed?
  • Microsoft Windows (7, 8, 8.1, 10)
  • Microsoft Visual Studio (2012, 2013, 2015)
  • CMake (3.4.0 or later)
  • Boost (1.56 or later)
  • LibUSB (1.0 or later)
  • Python (2.7.x)
  • Mako (0.5.0 or later)
  • Doxygen (1.8 or later, optional)
  • NSIS (2.50 or later, optional)
  • Why those all are needed if we are installing directly UHD ?
Message 24 of 31
(5,774 Views)
How to connect NI-USRP with PC by using NI-USRP configuration Utility?
Message 25 of 31
(5,772 Views)
BhanuRajput_India,
UHD is not needed to use LabVIEW. If you are using NI USRP hardware, all you need is the NI-USRP driver and LabVIEW. If you are using Ettus hardware, there may be other steps needed first to get the hardware recognized by your computer. What hardware are you using? I recommend looking up the corresponding getting started guide to get your equpiment up and running.
Message 26 of 31
(5,760 Views)
I am using NI USRP-2920.
Message 27 of 31
(5,754 Views)
Please tell me anyone exact procedure for FM implementation by using GNU Radio and NI USRP-2920 .
Secondly, by using NI USRP-2920 and LabView.
Message 28 of 31
(5,753 Views)
There aren't very many people that use GNU Radio on these forums. Most people use LabVIEW.
If you are using LabVIEW communications, there are several examples and guided help tutorials on how to use Frequency modulation.
If you are using LabVIEW 2016, I recommend checking out the community page: https://decibel.ni.com/content/docs/DOC-40622
There are several examples there.
Message 29 of 31
(5,751 Views)
  • Python (2.7.x)
  • Why those all are needed if we are installing directly UHD ? why all those needed if we are installing directly UHD latest version?
Message 30 of 31
(5,744 Views)
