USRP Software Radio
Can't find my USRP2 in the program.
Lastly are you using the original SD card? Some SD cards are not compatible. It may be that the card is not booting properly and entering an invalid state.
Message 11 of 14
(4,313 Views)
Yes, we are using one of the recommended SD cards.
But now we have gotten a new USRP N210 which is working fine.
Thanks for all your help.
Message 12 of 14
(4,301 Views)
It's great to hear things are working!
Please check out NI USRP Example LabVIEW VIs to view some the examples we've put together and please consider posting your own.
Best Regards,
Erik
Message 13 of 14
(4,298 Views)
Which daughter module do you have plugged in to your USRP2?
Another possibility is that you are using a daughter module that isn't supported by the NI USRP driver. With NI-USRP 1.0 driver, we've tested USRP2 configurations with the XCVR-2450 and the WBX module. Other daughter modules from Ettus may work, but we haven't confirmed nor tested the configuration.
Sam Shearman
Message 14 of 14
(4,278 Views)
