USRP Software Radio
Connecting labview with simulink
Hello every body
Could any body please help me in connecting labview with simulink my target is to capture data from USRP and then i designed model at simulink and this model will take it's parameters from the data received from USRP.
(6,136 Views)
If you require raw I/Q samples then you can save this complex stream to file in binary format and then read this in using Simulink. You could also use a TCP socket.
Depending whether LabVIEW is doing anything else other than streaming complex samples, you could use Simulink to directly access the USRP without using LabVIEW. See the following URL:
http://www.cel.kit.edu/english/simulink-uhd.php
Mike
Mike Jameson M0MIK BSc MIET
Email: mike@scanoo.com
Web: http://scanoo.com
(6,123 Views)
Thanks for reply,
but if there is any other solution that helps me opening simulink and getting results while I'm running labview
(6,111 Views)
We have a few different options. Can you describe the application further and what role each piece of software is fulfilling?
(6,105 Views)
