08-02-2020 07:44 PM
Dear All,
I come across an issue when I connect the USRP 2974 to my windows PC. It says "Could not reach the specified target"
Anyone knows the reason and how to solve that?
Thank you very much!
Solved! Go to Solution.
08-03-2020 11:59 AM
Hi, I solve the problem with the help of NI engineer. The problem is the PC and USRP need to connect into the same local net through the router.
