USRP Software Radio
NI-USRP2901 driver issues with UHD on Windows OS x64 v.19041.329
Greetings!
I have been looking to use the UHD libraries from ettus to develop to the C-api. Until today I have been able to run the example programs included in the UHD library through a installation of the drivers for the similar device of Ettus B200. But now since I got the new update my computer recognises the device as a USRP2901 and I can no longer connect to the device. I tried installing the drivers again for the B200 but that doesn't seem to solve the problem.
I attached two pictures. One is the new name of the device in the device manager. The other one is the installation of a new device at the same time as the new update where installed.
Is there a solution for this problem or is there another way of controlling the USRP by calling an C-api?
Thanks in advance!
(2,653 Views)
As I understand from your comment you are using B210 ( you can check it here  https://kb.ettus.com/Mapping_Between_ER-USRP_and_NI-USRP_Product_Numbers).
Please install this http://files.ettus.com/binaries/misc/erllc_uhd_winusb_driver.zip in your Windows Host machine and try again.
Best Regards,
bhovhann
(2,538 Views)
