USRP Software Radio
Daughterboard for USRP N210
Hello, i am looking at using N210 to sweep a low frequency range in MHz and also use a Rx board to receive a similar frequency. There are two options for the USRP - BasicTX/RX and LFTX/RX boards. will i be needing any extra hardware other than these daughterboards to do what i mentioned?
(2,750 Views)
Hi harip7,
If you already have antennas (assuming you aren't just performing a loopback) then you should have everything you need to transmit and receive a frequency sweep.
(2,732 Views)
