USRP Software Radio
error code -1074118627
Hi
I have a Ettus USRP N210 with a SBX daughterboard FPGA firmware release 4.
Labview 2012 SP1 (32-bit) and NI-USRP 1.2 on a 64-bit Windows OS
When I try to run any of the NI USRP VI like Tx Continuos Async it reports the following error code: -1074118627
niUSRP Write Tx Data (CDB).vi<ERR>A runtime or configuration error occurred. Code: 2410 Details: RuntimeError: LookupError: Path not found in the tree: /mboards/0/dboards/A/tx_frontends/0/sensors/lo_locked
Can anyone help me with this issue please?
With regards,
-Marco Bosco
(7,280 Views)
The error code, maybe, is related to a CARs (369233 and 322349). To resolve it you must update di firmware of USRP. Download the last available driver of USRP:
http://joule.ni.com/nidu/cds/view/p/id/3696/lang/en
and than follow the instructions on this white-paper:
http://digital.ni.com/public.nsf/allkb/F622E3B3B9CC34B6862579D500705272?OpenDocument
I hope that the informations will help.
Bye
(7,257 Views)
thanks for your answer.
I have the same problem with my new USRP N210. I have made the different modifications (update firmware) but no change.
Do you have solved your problem ?
(3,271 Views)
