USRP Software Radio
Error -1074118610 occurred at niUSRP Fetch Rx Data (CDB Cluster).vi
   I researched this error in forum ,however, I don't reach the solutions.
The received data is out of sequence. This may be a symptom of overflows due to an inability to maintain streaming at the specified IQ Rate, or rearrangement of packets by an ethernet adapter or network switch.
   When I start to USRP, I am taking this error 6-7 minutes later. I tried IQ Rate= 2M and samples per symbol=4 also IQ Rate is approximately 192k and samples per symbol= 20 for 9600 baud rate.
(5,415 Views)
Hello ITUbahadir
Could you tell me what example are you testing and what USRP do you have?
Any steps to reproduce? or I just should use the IQrate and number of samples you mentioned?
Regards
Frank R.
(5,397 Views)
I am testing my communication system which is using FSK and PSK. Also i have USRP N210. Then, you can use any value of IQ Rate and samples per symbol. However, I have to use 9600 bps. So, I try to adjust my data rate.
(5,392 Views)
Hello ITUbahadir
I understand you are NOT testing a LabVIEW shipping example. If this is correct, Could you try to test the shipping examples? Same error? If this is incorrect, what is the name of the example?
If the problem is specific to your code, could you share it? If you are not able to do that, could you explain me what have you changed to the code?
Regards
Frank R.
(5,378 Views)
