USRP Software Radio
Example of using usrp+labview to transmit ofdm
I heard that Labview has the most basic example of using USRP to transmit ofdm signals, but I haven't found it yet. So does this example really exist... or has someone done this before? Can you share it? Thank you very much!
(2,827 Views)
Accepted by lunaming777
Hi lunaming777
You should install the NI-USRP driver the first and then with help of LabVIEW find examples option.
From LabVIEW window go to Help > Find Examples and the search USRP in the search bar.
Regards)
________
Best way to thank is to give Kudos / Mark as a solution.
(2,769 Views)
Thank you for your answer!
But I didn't find an example of ofdm,o I need to install an add-on kit?(I already have a usrp driver and toolkit, as well as a labview communication design suite)
(2,752 Views)
