USRP Software Radio
How do I update UHD with RFNoC images for X310 FPGA?
Following the guide, I try to use [sudo] uhd_images_downloader to get the latest FPGA images. However, I only receive updates for usrp_x310_fpga_HG.bit which only contains the DDC and DUC prebuilt RFNoC blocks. I would like the usrp_x310_fpga_RFNOC_HG.bit image which contains many more blocks.
How can I go about this? I am currently running UHD 4.4. I have attached a screenshot of the output after running the image-downloader command.
(604 Views)
Did you ever find the bit image that includes some RFNOC blocks usrp_x310_fpga_RFNOC_HG.bit?
I am also looking for this.  The version I found is a couple UHD revs back and doesn't work.
Even a pointer to the Vivado files would help.
(184 Views)
I would also like an updated version of usrp_x310_fpga_RFNOC_HG.bit that works with recent UHD (4.9).  So far I have been unable to build one with RFNoc FFT from source that works.  The old one needs an older version of UHD.
(106 Views)
