USRP Software Radio
How to use USRP to signal?
I want to use USRP 2954(R) product. When I try to deliver a signal using this product, is the signal automatically generated within the device and delivered to the PC? On the contrary, what should I do to deliver a signal from the PC to the USRP? I will use MATLAB. I would appreciate it if you could tell me in detail how to generate and deliver the signal.
(1,628 Views)
Hi!
You might had better to read this.
https://www.mathworks.com/hardware-support/usrp.html
(1,596 Views)
