USRP Software Radio
USRP B210, PLL did not lock
Hi.
I have a VI that can transmit or receive radio frequency broadcast over SDR. I use two USRPs B210. I made it possible for my VI to run in multiple instances. I use one instance for receiving with one USRP (let's name it usrp1) and second instance to transmit via usrp2. I have a problem that when I start decoding I get an error (but not all the times, like in 80%) that says:
Error -1074118625 occurred at niUSRP Initiate.vi
Possible reason(s):
The reference clock PLL did not lock within the allotted time
the error also occurs when I connect only one USRP and one instance. It also occurs only with one USRP.
Can this be a problem with USRP and not my program?
(2,427 Views)
