USRP Software Radio
My Computer does not recognize usrp2
I am using desktop which provides 1G ethernet speed, and I use Windows7. Whenever I connect Usrp2 with ethernet port,
first, it recognize something is connected. Then, the computer says 'unidentified device is connected.'
I tried to connect it wtih NI-USRP, and UHD, but those can not find the device. I can not even start anything with USRP2.
I hope someone gives me the solution ASAP. I have to do it for graduation.
Please tell me what to do.
(5,422 Views)
I am making a few assumptions about your setup. Please verify them so that we can eliminate them.
  1. Is the host configured to use a static IP address 192.168.10.1 ? Setup Networking
  2. In my experience it might be beneficial to have just one driver on your machine at a time namely UHD or NI-USRP when facing such detection problems.
  3. You may use the NI-USRP Configuration Utility (GUI) to check whether your device is detected or you may use the find devices (.exe) utility found in the utilities folder of your NI-USRP installation directory.
Thanks.
(5,390 Views)
