USRP Software Radio
OFDM MIMO 4x4 with NI USRP 2920
Implementing MIMO 2x2 based on the link: https://forums.ni.com/t5/Software-Defined-Radio/6x6-MIMO-OFDM-System-with-NI-USRP-and-LabVIEW-Commun...  program works with the default parameters but when implementing a MIMO 4x4 system does not work, it only receives me noise. Someone who can help me please.
(3,907 Views)
Hello, I have just managed to get it work with for the case of 2x2 MIMO! Try to do the following changes:
1) specify the 2 ips of the TX and RX and deselect the remaining ones
2) IQ rate =0.5M
3) I used 4.4G as the carrier frequency
4) nofdm_symbols=16
5) sequence_len=8 and Nt=Nr=2 and set the custom params (at the OFDM params control)
6) the the timestamp to now
Hope it helps!
Evangelos
(3,866 Views)
I would like to know the parameters for 4x4 MIMO  to work. Could you help me with this?
(3,860 Views)
In particular I have a system design like the the following one:
I am sending you the screenshots of the TX/RX front panels
and also my custom global parameters:
(3,852 Views)
Thanks you so much
Thank you so much
But I do not work  4x4 MIMO  with those parameters maybe you have some idea that I can change to make 4x4 MIMO work.
Please.
(3,827 Views)
