USRP Software Radio
Record and Playback RF activity at 2.4GHz ISM band
I am very new to SDR. I need a low cost solution to to record all the interferences in the 100MHz band of the 2.4GHz ISM band (created by multiple WiFi and Bluetooth devices) and then play it back. I do not need to decode those signals. I am thinking of using B200 for down converting to base band, recording on a SSD and then playing back the signal using the B200 for upconverting to 2.4GHz. Considering the fact that B200 cannot cover the whole 100MHz BW, I am thinking of using three B200 with synchronized triggers, each set to a different band.
A few questions:
- Will such an scheme work?
- If yes, is there any GNU Radio Flow graph readily available for it?
- If yes, what issues shall I expect to be ready to deal with?
- Can multiple B200 be programmed to work in sync? If yes, what is the recommended source for generating the synchronization pulse? (another B200?) Any schematic for the needed HW connections for synchronization?
- If not, what other approach or solution do you suggest?
Thanks.
Message 1 of 1
(343 Views)
