USRP Software Radio
X410 100MHz Bw CLIP Clock Rate
Is there a way to change the 100MHz Bw CLIP clock rate to 125MSamples/s ? Actualy, it is 122.88 MSps.
When using 400MHz Bw CLIP, it is possible to adjust the sample rate to 500MSps using argument (master_clk_rate=500000000) , so i hope there is the same possibility using 100MHz Bw CLIP (master_clk_rate=125000000).
Any idea about feasability ?
Thank you
Best Regards
Message 1 of 1
(555 Views)
