USRP Software Radio
Synchronization of 4 pcs of Ettus USRP B210
I want to use 4 pcs of Ettus USRP B210 to be synchronized all.
Please let me know the available synchronization options so that 4 pcs of Ettus USRP B210 are synchronized all simultaneously.
Please also let me know the recommended models and configurations when it need to use external devices.
(449 Views)
Accepted by polo9
Option 1: GPSDO (GPS Disciplined Oscillator) for Each B210
Each USRP B210 can be equipped with a GPSDO module, which provides:
10 MHz reference clock
1 PPS (Pulse Per Second) signal
This allows each device to be synchronized to GPS time, ensuring all four are aligned.
Pros:
High-precision synchronization via GPS
No need for physical clock distribution between devices
Cons:
Requires 4 GPSDO units
Requires 4 GPS antennas with clear sky view
More power and cabling complexity
 Required:
4 × Ettus GPSDO modules
4 × GPS antennas
Power supplies for each B210
Board Mounted GPSDO (TCXO) | Ettus Research, a National Instruments Brand | The leader in Software D...
Option 2: External Clock and PPS Distribution (Recommended)
Use a centralized clock distribution system like the Ettus OctoClock-G:
Provides 8 outputs of 10 MHz and 1 PPS
Internally GPS-disciplined
Synchronizes all connected USRPs to the same clock and PPS
 Pros:
Centralized and cleaner setup
Only one GPS antenna needed
Supports up to 8 devices
Cons:
Requires external cabling (SMA cables for clock and PPS)
Slightly higher upfront cost for OctoClock-G
🛠️ Required:
1 × Ettus OctoClock-G
4 × SMA cables for 10 MHz
4 × SMA cables for PPS
1 × GPS antenna
OctoClock Clock Distribution Module with GPSDO - Ettus Research | Ettus Research, a National Instrum...
Also find more infomation on:Synchronization and MIMO Capability with USRP Devices - Ettus Knowledge Base
(420 Views)
