USRP Software Radio
TX and RX switching on N210 with SBX
Hi all,
I'm implementing TX and RX switching for half-duplex  on N210 with SBX daughterboard. I'm using one single antenna on TX/RX port. Basically everything works well by now. But I notice that I'm also receiving the signals transmitted by itself. And the amplitude of the received transmitting signals will be increased when I attach another antenna to the RX2 port.
So I'm wondering whether the device is receiving on RX2 port when it is transmitting on TX/RX port?
I referred to the TX and RX switching notes as in shown in Figure 5 here: https://www.ettus.com/content/files/kb/application_note_frontends_subdevices_antenna_ports.pdf
I believe when TX/RX is switched to receiving, the marked TX port would be connected to port 3 and the marked RX port connected to port 2 automatically. However, when TX/RX is transmitting, which means the TX port is connected to port 4, is the RX port connected to port 1 or port 2 at this time? Anyone knows about this?
Thank you!
Cat
(3,496 Views)
Hello wucc!
This sounds like an interesting application!  I'm curious, are you programming your N210 with the SBX daughter board with LabVIEW?  The reason I ask is because there are great examples of programming the Rx and Tx in LabVIEW when you download the NI-USRP driver!  You can then use the Rx or Tx Async examples to test, in loopback, whether or not the RX2 port is receiving when transmitting from the TX/RX port.
If you are using another language, I would suggest seeking help from the Ettus support team!
I hope this information is helpful!
Best,
Casey L.
(3,391 Views)
Hi Casey,
Thank you for the information. However, I'm using GNU Radio...Yeah, I'm going to contact Ettus for help.
Best,
W
(3,378 Views)
