USRP Software Radio
can I get GPS data with USRP-2922
I am new who learn Labview and USRP, I was doing a project about GPS Soft receiver with USRP-2922 recently. And I do not know this solution is able to solve the problem.
I have usrp-2922, two VERT-900 antennas and a GPSRSSMA active antenna , some attenuators, signal generator and PC.
I know usrp-2922 only has TXCO clock by looking at ni forum discussionsion I found I need add 10Mhz external clock or use hardware setup to import the clock to improve clock accuracy.
I have some questions about this project:
The most important problem is how can i get the proper gps data through usrp-2922 as RF-front. How to save and in which format to save these data on the labview. How to get a VI for processing GPS signals.
After the data is saved, I will use c ++ or mabtlab to settle these data.
Sincerely thank you for sloving my problems.
(3,277 Views)
hi Harry,
you should to scan the URL:
http://forums.ni.com/t5/USRP-Software-Radio/How-to-Acquire-and-Track-GPS-Signals-with-NI-USRP-2932/t...
Maybe it can solve your problems!
Thanks~
(3,229 Views)
Sorry, so late back to your post, that I see 2932 posts, doing well, his satellite signals are produced by local, I need to do is to collect data with USRP+ GPS antenna, using LabVIEW to drive the USRP to save data under the Windows system, and then for processing, but seldom can find related information
(3,127 Views)
