USRP Software Radio
Testing Rx LO Frequency
Is there a way to query the 2940R to find out the actual frequency of an LO?
I ask this because I'm currently using the Coerced LO Frequency output from the Configure Frequency VI in USRP 14.5 to do my input frequency calculations, and occaisionally, after changing frequencies, that output appears to be wrong.
Thanks.
(4,294 Views)
emonk wrote:
...I'm currently using the Coerced LO Frequency output from the Configure Frequency VI in USRP 14.5...
Oops.  A correction:  I'm actually using USRP 15.0.
Sorry.
(4,281 Views)
Hi Emonk,
You should be able to use this property, set it to read, and attach an indicator to it.
Configuration:Advanced:LO Frequency Property
http://zone.ni.com/reference/en-XX/help/373380D-01/usrppropref/pniusrp_lofrequency/
(4,256 Views)
