USRP Software Radio
The synchronization of USRP X310,how to deal with the question about frequency offset
Hi to all,recently i am doing a project about synchronizing two USRP X310,I add a training sequence before data,In the receiver,using the same training sequence to find the begining of data,then eatimating the frequency offset and recovering the orignal data,but the outcome can not estimate it correctly.Can someone give me some advise? Thanks very muchfrequency offset.jpg
(2,696 Views)
It is not clear from your description what you application does and what the problem is.
Is it possible to share the code?
(2,625 Views)
